Texasmark
- Dec 20, 2005
- 14,897
I decided to plug this in here as there is a stripped head bolt posting below and I have something to say about the subject. In my 50+ years of boating and personal mechanicing, I have had to deal with numerous frozen bolts on equipment of sorts including HD highway equipment, farm, and marine including salt water applications.
What works for me is a quality penetrating oil, an impact tool, and in severe cases, some heat.
Special sockets are made for impact operation. They work best and retain their shape.
The impact tool will hammer the bolt loose where attempting to unscrew it with a breakover bar and cheeter will either strip the head of the bolt or it, or the not impact socket will itself strip or break.
Numerous quality penetrating oils out there up to the task. Kroil is what we used at work and is the best I have found. It's pricy but worth it; doesn't take a lot. Aerosol is the most economical....www site.
Other thing about impact is that they do a great job of reinstalling hardware and getting it to torque spec without damaging the hardware. Outstanding on lug nuts on your vehicle.
Harbor Freight sells them at a great price and I have bought 2 over the years, both their brand, made in China....where else? Still haven't worn out the first and it has seen a lot. I just bought the second because I thought it might fail. Ensure that you keep them oiled with air tool oil, auto parts stores carries it. I squirt a goodly amount into the air inlet prior to attaching the air hose and give it several rips before using. Frequency depends on use......you can't over oil it.
HTH,
Mark
HTH,
Mark
