engine replacement...
jojo1975
my boat has a 1987 140hp Suzuki dt engine. and need to be replace.
I have found 2 possible replacement
1995 115DT Suzuki engine that was completely rebuild this winter all receipt coming with it and controls
or a 1999 130HP Honda engine with controls low hours under 100hours
witch one would you guys recommend ?
steelespike
I'm not crazy about 4 strokes; but I would go with the low hours apparently proven motor.
jojo1975
I went to see the Honda today. 170psi #1 170psi#2 120psi#3 and 150psi#4 so I choses not to take it right now. I wonder what could be the caused if any of you guys knows anything about Honda's 130HP 1999
jojo1975
also that engine is close to 400pounds not sure if my boat would be good for It its has a 140DT Suzuki on it now not sure if the weight of that old Suzuki is
jojo1975
supposely I did the compression test wrong by doing it cold when the engine had been sitting over a year. the local shop ran the engine to normal temps then did the test 182 182 167 172
does that make any sense ?????
steelespike
My info indicates Suzuki is 383 lbs,Honda 458.
It appears that Honda is a load
jojo1975
75pounds more. not to bad my transom should be able to handle that.
thanks
jojo1975
One last question. my suzuki I beleive has a 20'' shaft the honda is a 25'' will it fit ?
ondarvr
Yes, but no. You can put it on there, but performance will be poor and it may create handling issues. You need to stick with 20"shaft unless you want to raise the transom.
jojo1975
thank you! I have spoken to the Honda dealer that worked on it last and they informed me it needs a trim motor + 25'' is not recommended so I have pass on the buy. even if the engine only has 100Hours and the guys gives all the controls for 3500$ the trim motor is 2500$ so it becomes to much for me.
