- Mar 8, 2009
- 44,253
You had to know I could not let this go, being my Dad (union electrician Local 369 IBEW) is the one which taught me. Not to say I have not misunderstood something (as a non-licensed electrician). Sure this was years ago but just the same. Here is the books I have which I also used to rewire houses and received inspection approved. NEC 1990 and the 2005 Thompson Illustrated guide.
Wording in Para B -
Type in red above - This section corresponds to Section 210-5(a) and applies in general to all grounded conductors including feeder conductors. See Fig 210-4
The re-identification was done by making the white wire a lot longer then the others in the box
Wording in Para B -
A white conductor in a cable can be used as an ungrounded conductor when supplying power to a switch, but not as a return conductor from the switch to the switched outlet. The conductor shall be permanently re-identified to indicate its use by painting or other effective means, at its terminations, and at each location where the conductor is visible and accessible ** 200.7(C)(2)**. The re-identified conductor shall be any color except white, gray or green
Article 200 contains the grounding circuit identification requirements. The grounded circuit conductor is referred to thought out the code as the grounded conductor.
200-7 Use of White or Natural Gary Color. A continuous white or natural gray covering on a conductor or a termination marking of white or natural gray shall be used only for the grounded conductor.
Exception No 1: An insulated conductor with a white or natural gray finish shall be permitted as an ungrounded conductor where permanently re-identified to indicate its use, by painting or other effective means at its termination, and at each location where the conductor is visible and accessible.
Exception No 2: A cable containing an insulated conductor with a white or natural gray outer finish shall be permitted for single-pole, 3-way, or 4-way switch loops where the white or natural gray conductor is used for the supply to the switch. but not as the return conductor from the switch to the switch outlet. In these applications, re-identification of the white or natural gray conductor shall not be required
