Need info on fuel filter/ water separator. Will it remove 2 stroke or is it safe?
tuggeyt
Probably dumb question but, restoring boat and it still had the old fuel filter/ water separator attached to it.
It's a parker racor 320r-rac-01 with the racor s3227 filter. This hooked up to a Yamaha 115. Not sure if it was 2 stroke or 4 stroke.
I put a 100 evinrude on it that used to have VRO but has been disconnected so need to use 2 stroke now.
I have tried googling it but there's no answer for actuall Parker racor filters. The replacement filters Seirra and Mallory state that they
do not remove 2 stoke but I can't find any listings that state if the racor does.
alldodge
No, none of the fuel filters that I'm aware of remove oil from gas. If they could the gas would have a real hard time passing through it as well
F_R
That remove-the-oil thing is an old wives tale that refuses to die. Just simply not true.
Just for fun I used to go into hi-fi / stereo shop and asked if the " noise filter " on my amplifier needed changing.---Try it sometime.----For my truck I ask for a longer dip stick because the one I have does not reach the oil.----Always worth a chuckle.
nwcove
lol racerone.....ask for that longer dipstick for your truck at any canadian tire store.....i guarantee the kid behind the counter will ask you if its 2wd or 4wd!!
F_R
Hilarious, but so sadly it is true. Not just Canadian Tire either. But I have to admit our local NAPA is pretty professional. Unless you ask for Sierra parts. Most never heard of them.
gm280
I have run hundreds of hours using 2 cycle gas/oil mixture engines in boats and other equipment and not once did I ever use any fuel/water separator and never had any issues either. Am I missing something here?
