Motor Help
rnewlon
I just bought a 1972 Glastron Swinger, It has a 1972 Evinrude Triumph on it. Put the lower unit in a barrel of water today to run it a bit, see how it does. After running for just a few seconds the previously clear water in the barrel was cloudy, and it appeared to be oil of some sort on top of the water. Motor fires up great, idles fine and revs fine. Concerned about the "oil" any ideas?
That is normal for a 2 stroke engine.------This has been explained a 100 times and maybe a few more.
nwcove
barrel running or on muffs you will see a bit of a mess, and after a day on the water you will probably have oily drips showing up. as mentioned, it is normal for a two stroke. if it seems excessive, start thinking about a tune up.
Bosunsmate
You guys rock, Thank you, made me feel better about it!
Just dont think about where that oil normally ends up. Lots of two strokes here in New Zealand, i hear they a banned in many other countries in certain rivers and lakes due to the oil residues. It would be good if water cooled two stroke oil broke down quickly but ive never heard of that being the case
