ferrellrooster1
Thread starter- Joined
- Jul 8, 2013
- 8
I posted about this a year or so back. Unfortunately work takes up most of my time to do ANYTHING. And the engine has been sitting up. I finally got a little time. Let me start from the beginning:
2004 115hp Yamaha 4 stroke. I had run this boat a week before about 25 miles or so with no hitches. The following week I launched it, went to crank it up, it started for a bout 30 sec.then died. I atempted to crank on it. Nothing...I lifted the motor and a bout a half to a full cup of gas poored out. I let it set and tried to crank it again. it fired up then died. I lifted the motor again and a cup of gas pored out. So I loaded it up. I thought an injector was stuck open or something. So I cleaned the entire fuel system lines. from the big filter, to the water separator, to the fuel cooler, vapor separator, float, fuel pump, all the lines. Basically from the gas tank to the injectors.
Put it all back together, pressurized the fuel system (last week,) ..........same thing. So im guessing...and this is guessing, that it is one of many things,
1. fuel bypass check valve?
2. stuck injector? (But they are clicking so im assuming they are working, did not check resistance)
3. temp sensors???? WTS TPS or ETS....depending on who you talk to for the correct name. Air temp sensor or the water temp sensor. The water temp sensor provides essential info during cold start and warm ups. With the flooding Im wondering if this is the culprit.
4. AIP/MAP???
Im just looking for some help narrowing this down without having to buy parts to find out and get to the problem. I do have a SELOC 1705 but its not a trouble shooter. Its a repair manual.
Any..and I mean any help, suggestions, heck sarcasm for that matter is greatly appreciated.
Thanks in advance,
Respectfully,
FerrellRooster
4. AIP/MAP???
Thanks in advance,
Respectfully,
FerrellRooster
