- Jul 23, 2011
- 51,882
start by removing the drive. this will let you know if the issue is the motor or the drive.
I pulled the outdrive already and still the same knock, I remove valve cover gaskets and clean oil, not metal.
the distributor never got loose but I was reading that a bad mixture carburetor can cause spark knock, how the noise will go away, how can I fix this.
well time to pull engine out and inspect, my friend who is a master tech is help out, we remove oil pan, and not metal or any particles around clean oil, remove and inspect main bearing and connecting rod bearings and not signs of wear or damage,
ok guys little update here founf the issue, like I said bearing are good, take out the heads to find out cylinder number 7 has some metal big parts on top of it, I don't know hoe this got there the only explanation is thru the intake and most be something from the carburetor.
