Stuartmacg
- Jan 1, 2015
- 7
Hi guys
Happy new year from a new member.
I have an Evinrude outboard as above. The issue with it is I have lost ignition on #2 cylinder (bottom one). The engine was running sweet when the #2 cylinder just completely died.
On returning to dry land this is what I found. From the underside area of the flywheel there was a BLUE/White tracer wire that appeared to have broken off. End of it was all frayed,but there was no obvious sign as to where it came from. The wiring for #2 cylinder is BLUE/White tracer. I tested the wiring Blue/white tracer right back to the ignition switch and it was dead all the way. The BLUE wire from the ignition for #1 cylinder is powered up at all times from the ignition switch when the switch is on and the motor running. #2 cylinder-BLUE/White does not appear to be powered at all when the motor is running.
I am suspecting the ignition switch first up but I am also concerned as to where the BLUE/White tracer from the flywheel should be connected.
All and any help and information will be gratefully received.
Stuart
From down under in New Zealand.
Stuart
