Unknown Johnson gear case
Tempest 160
Just wondering if anyone has ever seen one of these? I recently acquired this 1976 Johnson 20hp motor, model # 20BA760 but I can't find any info on it at all. I've had Johnson and Evinrudes for many years but have yet to ever see one with this gear case, it has fins already molded into the lower half of the gear case, they are not a separate item. The unit still works perfectly and is in quite good condition for it's age. If you can offer any ideas on it I would love to hear them. Thanks..
82rude
interesting.cant wait to here from the more knowledgable omc guys.
boobie
They were put on there to try and help stabilize the boat. Not very successful .
Operated one of those one time.------Turning the tiller handle at speed made the boat lean and those fins took over and pulled the stern,--Scary it was.
Chinewalker
They were included on some of the heavy duty "Worktwin" models, in 20/25 and 40hp flavors. They were there as a propeller guard.
hardwater fisherman
Yes I know what you mean. I am resealing the gearcase before next season and I was already thinking about trying the regular skeg off my parts motor.
boobie
You can't interchange skegs because the lower unit is line bored at the factory with the skeg in place. Yes I know, some people have done it.
Faztbullet
Its actually a weedless lower unit (note prop design) for shallow water operations
Faztbullet
It is a commercial motor, most likely Canadian made and unit designed to deflect weeds and debris away from prop. Prop design rarely allows WOT operation as it cavatates easily. Info from good friend/retired OMC service rep that hangs out over on AOMCI site.
