Boat fender size
seratime
Hi Folks...what fender size would I buy for a 23' Bayliner Cierra cabin cruiser:
6.5x23 or 8.5x27
Thanks
thumpar
I would go with the bigger ones. You can't really go to big (At least within reason) but you can go too small.
gm280
With absolutely no other information or pictures provided, I'd go with the larger size any time IF it fits! The larger fender will stop more water, dirt and mud from slinging on the trailer and boat. But to verify that size you either need to provide more info or better yet, post some pictures for everybody to see what you're seeing... Of course this is all useless if you're talking about fenders for the boat itself...
dannys2004glastron175mx
I think the OP is talking about fenders for docking his boat .:peaceful:
alldodge
Bigger is always better, storage space in most cases is the issue. I use 6.5 diameter ones for my 23 footer, and make sure they pumped up
Edit: after rethinking I think there in the 8 inch size. Boats covered up and don't want to uncover to check
JoLin
A good rule of thumb is one inch diameter for every 3 ft of boat length. I'd go with a minimum of 7.5, or in this case the 8.5's you're considering.
Frank Acampora
Definitely the 8.5. Also investigate the fender mounts that attach to the bow rails. Keeps the stored out of the way. Since any fender tries to roll up off the hull under prolonged docking look for different shapes than round or connected fenders if this is the use to which you will put them.
