Any HP parts for a Mercruiser 3.0
RAVEN893.0
I have a 19 ft Raven with a 3.0 Mercruiser.My question is, Do they make any High preformance parts for this little 4cylinder 3.0 engine? Cams,Rocker arms,Carbs,Props? Anything i could do to get a little more HP out of her? Thanks for the help! :)
jeff13601
Re: Any HP parts for a Mercruiser 3.0
Get a small six cylinder. Just kidding, although for the money it would cost you would probably be better off. Some of the more experienced motor people will prob have some answers
RAVEN893.0
I would do a 6, but my 3.0 is only 2 years old.It has maybe 60 hours on it.Thanks Jeff13601
jeff13601
I would probably be willing to buy it off you when you decide to upgrade, lol. What part of new york
RAVEN893.0
I live in Long Island NY.If i upgrade ill let you know.
jeff13601
Ill be waiting...Welcome to iboats
mikebc
What prop do you have on? I had the same problem, looking for a "magic bullet," is a tuff one with the 3.0. I found by stepping down a few pitch #'s to a 18 with 4 blades helped a ton. I hear ss props are a bit better too. Good luck!
mikebc
P.S. Someone on this site just posted how to drill a small hole on each blade, I've heard great things about this, but I think it's easy to ruin a prop if you don't follow the directions.
RAVEN893.0
I have a 3 blade,Not sure what pitch # it has.Im guessing it would be the factory pitch? Ill take a look to see,Ill let you know.
mikebc
What are you looking for, top speed or getting up out of the water faster? You also need to note your top rpm's at wide open throttle. The specs should be on a label on the engine, but I think you should be running 4,500 rpm +/-, but check your label, should be under the oil fill. If yours id like mine, it has a 19 on it, I stepped down 2 sizes and WOW, pops out of the water like a v8, but I have to watch my rpms, if the boats empty, low on gas, and not towing anything I will get up close to 5,000 rpms, to high. Most of the time I have a full tank, 4 people, 200lbs of gear, and towing a tube or skier, then I only hit 4,500 on a good day!
novicetech
Rodbolt had a post awhile back about a 3.0 that generates 180 hp from marine power. I know it has mpi and proibably a vortec haed of some type. I would like to have more info also.
Nope,.................... <br /><br />There was a Custom-Built Turbo set up on ebay about a year ago......
RAVEN893.0
Mikebc the # that i got off the prop ended in a 17p.So what do you think?
jeff13601
If it hasnt been worked on it would be a 17 pitch
RAVEN893.0
I guess ill have to either sell the boat and buy something with a bigger engine,or just put a bigger engine in the boat.
RAVEN893.0
Does anyone know what size rocker arms are in a 3.0?
