Problems with Link N Sync Johnson 25 1990 J25RLESB with 35hp carb
patricio
Hi, since the motor sneezes when throttling down after the carb change i went out today to watch how i could do a Link N Sync on my engine and a saw a problem.
I found a description that says that i should with the engine off put the control in forward gear and move the throttle until the cam marks are centered with the roller and then loose the screw on the throttle butterfly lever to push up the roller to the cam.
Well on my engine the marks have already passed the roller when the control is in idle, not even in gear, what's wrong? Should it be like this? The engine has been running fine with the original 25hp carb.
If i push the cam with my hand it just returns to the position when i release the pressure, if i give throttle with gear the cam advances but the marks are never centered, any one knows if it should be like this?
I took a pic on it when the control is in idle.
What i mean with control is the stick, it's not a tiller model.
The engine runs fine on idle all the way to full throttle, the sneezes occure on the way down to idle, this is tested on the water with running boat, not with muffs.
Thanks /Patricio
Post a picture of the adjustable collar at the back of the long rod .------A picture when control lever is at nuetral ( idle ) is what is needed here.
patricio
Hi!
I'm not sure of wich collar you mean, is it the collar on the rod seen on the picture? The one that goes to the right in the pic?
Thanks /Patricio
patricio
Went out today and took pics of the whole engine, hope it helps :)
The control lever is in neutral when the pics were taken
I noted that the spring seen on the last pic is what retrieves the flywheel and make the cam go pass the roller to the left, is it that spring that's lost tension and needs to be replaced?
Thanks /Patricio
IMG_5589.jpgIMG_5590.jpgIMG_5591.jpgIMG_5592.jpgIMG_5593.jpgIMG_5594.jpgIMG_5595.jpgIMG_5598.jpg
That adjustable collar usually has about a 1/4" gap on it.---Often folks adjust that because it " appears to be wrong " to them.------This opens the throttle too soon if not properly adjusted.
patricio
Ok, thanks for the answer!
Went out in the dark to try a Link N Sync, with that spring removed i can manually move back the flywheel making the cam pass the roller, this way i made the Sync and then giving it full throttle i unscrew the collar on that rod and locked it so the throttle lever in the carb is fully open.
I will try it out in the water as soon as possible and come back with the results.
Do you think the timing will be alright even if the marks on the cam with the spring on dont return far enough? The flywheel doesn't return all the way when i return the control lever to neutral, i suppose it's been like this since i bought the engine.
That spring is part of the nuetral interlock.----Prevents high throttle in nuetral.-------What are you saying when you say " flywheel does not return all the way when I return throttle to nuetral "----------The flywheel or the magneto plate , which is it ????
patricio
Oh, i may be saying the wrong name :)
I mean the plate the cam sits on and wich is retrieved further when the spring is on but not as much as i think it should.
I also noticed that the metal pointed on the pic attached here touches the black stick to the right that goes down when i get in forward gear but not far enough, so the metal part touches it on the way to the right when i throttle up, i also feel that touch in the control lever and have to push som extra to make it pass.
A lot of questions :) Sorry
Thanks for the help!
jasper60103
The "black stick" is the neutral start plunger (#84). It should drop lower when in forward gear allowing the plate to pass. There must be some adjustment needed.
http://www.marineengine.com/parts/j...urer=Johnson&section=Cylinder+&+Crankcase
patricio
Ok, to close this thread, the problem i had with the plate (retainer plate?) that the cam with the mark sits on, the problem was solved by adjusting the throttle cable, just turned the adjusting device (don't know it's real name) and got the plate to return were it should be and by that making the cam marks return passing the roller to it's left (viewing from the front), this also lowered the idle rpm.
And the black stick problem (the neutral start plunger) went all the way down turning the prop, a problem not existing when engine running as the prop turn when the gear engages.
Thanks to everyone that answered and hope my answers help others with the same problems, it's nice to learn and fix things self!
