Engine mount Question
betayv
hello guys and thanks again for the support, 1987 searay 350 engine, very disappointed with the engine mounts shot on the boat (not the one on the back on engine), the ones in front, the center bolt is shot very rusted, so need to be replaced, what is the best way to do this, The outdrive have to came out?, any advice thanks.
alldodge
If it's just he center bolts or the motor mount, clean it up and reinstall tight after engine alignment. If the mounts are soft, need to rebuild the stringer and mount. Could use some pics to see what your running into.
Yes, remove drive for any work on engine mounts
betayv
Is just the center bolt the mount is solid, I don't know hot post pictures how I do it?
alldodge
Either use photobucket or upload the pic by selecting the icon which looks like a tree.
Now if you use the engine alignment bar and your drive is in alignment then wire brush the bolt, add some paint and relax, there is no issue
