Ricky_rich
Thread starter- Joined
- Mar 4, 2014
- 151
I'm having problem with to high idle on my engine. Carburetors are all closed but engine rpm is rising to high level.
I wan't to check with you guys that I have the timing right. I have set the three masks on flywheel against the arrow on alternator pulley at TDC. When running the engine and using a strobe on cyl 1, I get a reading as the attached picture shows. The three marks are at approximately 18 degrees and the line to the right next to it at about 38 degrees. I know my scale is unreadable but I have compared it against a good one. So is this correct timing for my engine?
