adominique0313
Thread starter- Joined
- Sep 23, 2014
- 50
Does anyone own a 1968 Johnson Repair manual that would be willing to share info?
Thanks
Andy
Thanks
Andy
F_R I would like to thank you so much. you were spot on. fired it up this after noon and runs good now. one other question then I will leave you alone (maybe) actually this is a two part question 1. Above the carburetor there is a piece of aluminum angle that is holding the starter and alternator, it has a set screw and a piece of nylon plastic goofy looking thing on it. Is the set screw supposed to be all the way in? (mine is all the way in) and what does it do? 2. how does the lean-rich needle work that is in front of the carburetor? do you know where a good starting point is to set that? I had to adjust it a little however, the engine still spits and sputters at idle every so often. Should it spit and sputter? It runs and I adjust it and I go lean it starts spiting and sputtering bad then I go rich and it stalls. if I go in the middle of the two it idles good but it spit and sputters here and there. Thanks again AndyMake sure the high speed orifice plug is clean. Not just clean, but CLEAN without a trace of any dirt or varnish or anything. And replace that gasket. And make sure it is running on both cylinders. Yeah, I know, everybody disputes this when we suggest it. Finally, the throttle linkage rod if somebody has been messing with it. Opening too soon will make it fall on its face.
