New owner: 1988 Sunbird OMC Cobra 3.0 ignition issue
Hello, new member here and first time boat owner. Bought a 1988 Sunbird w/ OMC Cobra 3.0(paid less than the trailer alone was worth).
Preface: I'm pretty mechanically inclined having spent many years working on cars.
The boat was sold on the premise that the owner thought it had a cracked block but couldn't really tell me why, just "wann't runnin right". So i get the boat home and start opening it up and see that he removed the head, starter, coil, and so on. I was to simply reassemble it and try and figure out what is actually wrong with it.
I installed the starter and coil and the engine cranks nice and smooth(head not installed).
So I move on to checking the ignition system. Spark plug sitting on the block: no spark. Screw driver in the coil wire and near the block: no spark.
Checked the (+) on the coil with my DVOM: 0v with key-off, 12v with key-on(which either stays 12v or quickly drops to either 9v or 6v. It seems to be different each time the key is turned on), 9v with key-start.
Also noticed that the starter terminal which goes to the coil reads 4v with the key-off. Is this normal?
Here's what I think I know, correct me if I'm wrong: There should be 0v with key-off. There should be 9v with key-on/run. There should be 12v with key-start.
External resistor reduces to 9v with key on/run to preserve the points. Secondary post on the starter becomes energized while cranking and supplies full battery voltage only during cranking.
Last thing I noted is that while there is no spark while cranking, there is one spark when the key is returned to on/run.
Could this have something to do with the ESA and related switches? (I have no real knowledge of this part of the system. As I understand it the ESA reduces ignition power to stumble the engine for gear change?)
Thanks in advance.
Jesse
bruceb58
The voltage you measure at the positive side of the coil with the key on will depend if the points are closed or not.
First thing I would do is to install a new set of points and condensor before you did anything else. To get the ESA out of the equation, just unplug it until you get the engine running.
I found the sticky about troubleshooting the ignition system and saw that anything from 4v - 9v is correct with the key on/run so I guess I dont have a problem there but I'm still thinking that there should be full battery voltage at the (+) terminal on the coil when cranking.
Disconnecting the gray wires from the (-) terminal on the coil does not change anything. Does this fact rule out the ESA system?
Need new points and condenser perhaps?
