4 HP Model E4RDHLCUD Serial # B1384573 (1987)
Engine starts and runs fine in neutral. Stops instantly when I shift it into forward or reverse at the shifter. There was a squeak/squeal of unknown origin for a few minutes before this malfunction occurred. Shift lever works smoothly and enters click detent without any resistance or looseness.
Also if the squeak at the beginning indicates a bearing gone bad at the engine/lower end junction. Pull start easy in N (starts) but more difficult in F (or R) and doesn't start. Good flow of cooling water. Thanks for the help
