Manually wiring the kill switch for 1986 70 hp
unspin
The pin in the wiring harness for the kill switch broke off when i was moving the engine, would someone be able to advise how i can manually wire the kill switch in?
I'll get a new wiring harness eventually but they are hard to get and will probably take a week or more to get here
alldodge
Without getting into the wiring info of your engine, it is my under standing that a pin inside a connector broke off which controls the kill switch. So one side of the connector will not make contact with the wire on the other side of the matting connector. If this is true, run a jumper from the backside of each connector which will make connection bypassing the pins.
