blue89turbo
Thread starter- Joined
- Nov 16, 2009
- 40
Hey guys,
Just looking for some help on my 350 magnum.
Everything was fine yesterday when I launched the boat and came around the pier to my beach. I anchored for a short while. When my wife and I wanted to head out to a different beach a few points over then the problem started.
Here is what happened.
The boat started and ran fine but as soon as I tried to slide the shift level into forward it would want to die. neutral and reverse worked fine.
I also noticed that the lever would bind a bit at the end of the forward travel...( i think this was from the switch binding with the "bump" on the shift bracket?)
I ended up playing with the adjustments but still could not get it to run and shift into forward...I ended up removing the interrupt switch so at least I could get going in forward.
I am thinking that the shift cable could be worn?
Maybe redoing the adjustments per the specs could help?
Maybe the shift interrupt bracket and switch could be a problem?
I am always hands on but I really wont have time replace the cable this week and my wife really wants to use the boat next week on our holiday...
I may try to readjust the cable per specs tonight but if that doesn't work I may bring it in to the local marina for the work to be done... Any ideas on the cost for a new cable and the labour, as I know the drive needs to come off...how about the cost of the bracket?
Thanks for the help!
