Tune up 2001 Mercruiser 3.0?
sharky08
Im needing to tune up my 2001 Bayliner Capri, It has the 3.0 Mercruiser in it and I havnt had much luck finding what the correct replacement parts are. If someone could lead me in the right direction for plugs, wires, fuel filter, oil, oil filter and direction on the easiest way to do all this. Thanks!
alldodge
:welcome: to iboats
Could sure use your engine serial number to be sure. Is your engine an MPI or carbureted ?
If it is MPI the following is probably the parts you want
plug wires 84-816761Q14
fuel filter 35-866594K01
oil filter 35-866340W03 (Mercury) or 35-866340K01 (Quick Silver)
oil Quicksilver 25W-40
Spark plugs AC - MR43TLS or
NGK - BPR6EFS
If it'd a carb let us know
sharky08
It has a Carb. Thank you for helping a new owner out. I am finding out that Im sorta green.
