Intoodeeep
Thread starter- Joined
- Aug 13, 2011
- 64
My 1988 Johnson 175 is stiff to shift at the engine. For those that have read some of my previous posts, this is the 1979 engine build. I have had a few issues and I know it is coming to a point where the lower unit will need to be rebuilt or replaced next year. Just a few goofy things it is doing. I have yet to have it out on the water yet. But it wasn't stiff to shift until after I had the engine running for an hour in the driveway to start the break in process on the motor and look for leaks and problems. I have pulled the lower unit and it shifts fine there. I do have to spin the prop to get it to engage but it does engage. The shift lever at the motor shifts clean and free as well when not hooked to the shift rod. It is only stiff when it is all connected. The shift rod is at proper height per OMC manual. Ideas?
I have been having issues with being able to engage forward and reverse from the control box. It is either one or the other. I can get it to engage now but it has to be past the detent for forward or reverse to engage. I just replaced the internal gears for the control box. But it slips out of position sometimes due to the shifter being stiff now. Which it wasnt before.
