starter selnoid by pass???
siego99344
hello y'all Question I got a 78 ford 351 omc. I noticed that it has 2 starter selnoids. 1 on top if engine that connects positive battery cable then runs down to the other starter selnoid attached to the starter. could I by pass the starter selnoid thats sits on top of the engine? and run power cable directly to thw main starter selnoid attached to the starter???
Ayuh,.... If ya do that, the keyswitch carries the amperage, 'n it Don't like it,....
Cleanin' All the wirin' end connections to Shiny metal Clean fixes most startin' issues,....
Greasin' 'em after, keeps 'em that way,....
siego99344
yes thank you I will just order a new one this one is all old dirty and corroded
Bulbash
Not a good idea... I guess that's how boat fires happen... :))) Just get a new solenoid... its around $20 - $30...
siego99344
yea just bought a new one $20 but I still think setup is iffy to me.
siego99344
hahaha well chevys only have 1 starter selnoid thats on the starter this ford has 1 frpm battery to starter selnoid then down to the ot he starter selnoid thats attached to starter I thought 1 starter would do.
xltier
it also acts as a slave switch for the neutral safety
Maclin
Separate starter relay, not embedded in the starter. Good design to keep relay from soaking up heat. Also can be a meatier unit when separate, not limited by having to fit in with the starter itself. In the Auto world Chrysler and Ford back in the day anyways had the relay separate from the starter, nothing wrong with that, and has advantages. I like to rely on the engineering from the manufacturer, keeps me from falling out of the pan into the fire so to speak.
