Sea Ray dealer says I need a new ECM for 5.0 MPI
Bravo402
I was just told by the Sea Ray dealer that I need a new ECM for my 5.0 MPI Bravo 3 at the tune of $1,950.00. According to them they had to bring in a mercruiser rep to look at my boat. The boat shut down while we were cruising in the lake. No spark out the coil. The rep replaced the ECM with a new one he had and the boat ran. My question is there some where I can send my ECM to be repaired or purchase one cheaper than the $1,950.00 they quoted me. Thanks guys
Fun Times
Hi there, Do you have your engine serial number handy? What year?
What is thought to be wrong with your old one?
Depending on ECM type and problem, there might be a repair facility to ask.
tpenfield
Yea, pricing for ECM's is a rip-off. List price on those things is over $2K.
If you Google ECM repair, you will find some places that repair them. Automotive for the most part, so you would have to see if they also do marine engine versions.
Bravo402
It's a 2003 engine serial number OM653566. I did a google search on it but found repair shops for automotive. I figured I would check here before I started calling these shops
Bravo402
Think it's the ECM 555 model. We didn't say other than the rep put a new one on and the engine ran
tpenfield
If you were going to fix this yourself, then you could probably find a lower cost approach (eBay, ECM repair company, GM parts, etc). But through the dealer or repair shop, it is costly.
alldodge
Your engine serial number come up with the 555 ECM part and one of 4 part numbers
865835T02 (5.0L MPI Alpha)(Standard Cooling) SN# 0W029411 & Up)
865836T01 (5.0L MPI Bravo)(Standard Cooling) SN# 0W029411 & Up)
865837T01 (5.0L MPI Alpha)(Closed Cooling) SN# 0W029411 & Up)
865838T02 (5.0L MPI Bravo)(Closed Cooling) SN# 0W029411 & Up)
Edit: lowest price found for new is around 1300
Bravo402
Thanks for your help AllDodge mine is standard cooling bravo when I go pick the boat up I will get the part number off of it.
Fun Times
The ECM part number your looking for is 864376T05 which has now superseded to 864376T06. Also, there should be another part number on the ECM itself and it may be different then the two numbers I just posted. Be sure to search both online and on ebay using all the part numbers to help find the best deal for you.
http://www.mercruiserparts.com/Show_...cal+Components
http://www.psepmarineparts.biz/store...cm_modules.htm
Your complete parts catalog, http://www.mercruiserparts.com/selec...doc_nbr=884717
There are two marine repair facilities you could try contacting to see if they can help, both are in California.
First try http://whipplesuperchargers.com/inde...&product_id=73
Then http://www.simonmotorsports.com/ecu/optiecu.htm
Bravo402
Fun Times you the man $500.00 sounds a whole lot better than 2,000.00! Thank you all for the help! Awesome website!!!
alldodge
OK I'll ask, Merc's website shows the part numbers I list above, where did yours come from and why is Merc on site in error?
tpenfield
So, do you just tell the dealer to take back the new ECM and give you back your old one? I would make sure to get it back, since it could be repaired and kept as a spare or sold on eBay, etc.
AllDodge, I came up with slightly different part numbers for the ECM as well, using mercruiserparts web site. there was a serial number cut-off in the notes and the OP's engine was below that cut-off.
This thread has prompted me to do a little investigation into the control module on my engines (plural). Looks like I have the MEFI-1 variety . . . Having one of those fail would be a real budget killer. I notice that automotive varieties of the control modules are about 1/2 the cost of their marine equivalents :rolleyes: :facepalm:
Bravo402
The dealer exact words to me was they couldn't get spark out the coil either (I replaced everything the book said to do. I thought they would scan it which I guess they didn't here is why. He went on to tell me they called in a mercruiser rep and he had another ECM on his truck and changed them out and the boat cranked right up like it should. He then reinstalled my original ECM and the boat wouldn't start. And that's where they came up with I need a ECM. I didn't buy it from them just paid them to tell me what was wrong with it. Since I thought it might be the ECM I wanted be sure.
Bravo402
What has me a little scared is the fact the dealer could not tell me what caused the ECM to go out
Fun Times
Bravo402's serial number starts with 0M, the serial numbers shown above are for the 0W and above, his engine model would need the 0W and below.;)
Also in post #8, he mentions his is standard cooling which coincides with looking up his serial number as standard cooling and not closed cooling that could have been added later. If he didn't mention standard cooling, we would have had to ask him if he had standard or closed cooling to confirm the correct part number.
First run the serial number to confirm their engine model and parts catalog part number, then go to the website I linked above for both the most latest part numbers and the original part numbers. The Merc website were you punch in the serial number only shows the original parts numbers, it does not show or keep up with the superseded numbers. You'd have to pull them numbers and run them in another area to get the latest numbers or go directly to the other site after confirming what the OP really has.
The best place I have found on the internet that keeps up with the latest parts info as Mercruiser changes them near daily it seems is here.http://www.mercruiserparts.com/partsByNumber.asp
Fun Times
If yours goes out, then this place might be able to help. http://www.mefiburn.com/ and maybe here, but I'm not sure of it. http://www.technicalservicesin.com/index.php?page=ecm
Also lots of reading here for the MEFI system, http://www.michaelstractors.com/forum/topic.asp?TOPIC_ID=199
alldodge
:facepalm: transposed the M to a W, thanks for checking Fun Times could have sent the guy down the wrong path
Fun Times
No Problem AD, When it comes to a lot of these multiple questions day in day out, there is no i in team here, it takes all of us to try and help the best we know how.;) Sometimes we get it right, sometimes we don't. At least we tried.:)
tpenfield
Looks like these many of these ECM's are made in at the AC-Delco, now Delphi Automotive Systems plant in Kokomo, Indiana . . .
I spent a day at their plant way back in the 1980's during my Industrial Engineering days . . . The company that I was with at the time supplied many of the digital dashboard display components for GM cars.
Bravo402
Will a ECM from a 6.2L bravo work? The number for the 6.2 L is ECM 5550204 same as mine now but I have a 5.0 L
