remote controls johnson 70esl75e
john99
I am having a problem with a remote control shocking me when motor is running, have a new switch and wired correct , no frayed wires , does not do it when out of the water
. it started just fine the first few times when on the lake, but at the boat ramp when we were taking the boat out ofthe lake ,when we tried to shut down we got a shock need help!
emdsapmgr
The ignition switch has a single wire that goes direct to the power pack to ground it out when the key is turned to off. You may be getting voltage back thru that wire from the power pack. In later years that is a black wire with yellow tracer.
Fleetwin
Yup, that wire is pinched in the case half. It probably happened when the new switch was installed. Been there.
tblshur
john99 you might try cleanning connections and checking for tightness on the black wire from keyswitch to motor maybe crorosion in red plug or whatever plug it is good luck and :welcome: to the forum
john99
Thanks for all your help, I will check out all the wires that come from the remote to the power pack, thanks again. john99
john99
