Gilded_Splinters
Thread starter- Joined
- Jul 25, 2012
- 64
In the interest of not dragging you all through another over heat thread, I'll let you know what I've done and learned and the last things I've boiled it down to.
1989 OMC Cobra 5.7 liter. Over heats at higher RPMs, but does not cool down at idle.
The boat never had thermostats in it. Always ran @ 120. Before launch this year, I put them in. Found an accumulation of rust scale in the recess in the intake manifold under the thermostat housing. Removed rust scale with magnet. Installed thermostats, test ran and overheated. Removed thermostat in over heated engine out on lake. Found more rust in intake, removed with magnet. Temps dropped as I had hoped, but things have never been the same.
A third inspection a week or so later revealed no rust at all, so I thought I had gotten it all. I should add that this rust looked as if it had been bouncing around in there for decades. It was black and soft and easy to crumble. There was no red, fresh looking scale.
So here's where I'm at:
Either there are rust/mud/gunk obstructions in the block or there are flapper bits clogging up exhaust passages. The flapper's condition (or existence) is something I plan to check on as soon as I can.
Any thoughts or suggestions would be greatly appreciated. I've about had it with this thing.
Thanks.
- All raw water tests performed. Plenty of water coming in, no air being pulled in while on plane. No obstructions at all. Again, good water flow, pump is fine.
- I found risers very clogged. Manifolds only clogged below riser gasket area, once cleaned out, manifold water jackets appeared wide open. Risers replaced, but I neglected to inspect flappers while is was right there. Ugg.
- Test run post riser install showed abnormal temps considering there are still no thermostats. It ran @ 160 or more and might have over heated, but should not have exceeded 130 as was normal up to this point. It should be noted that before the riser change, it got much hotter, much faster, so this represents progress. The risers were so clogged, that I'm surprised that any water at all got through.
Thanks.
