dingbat
- Nov 20, 2001
- 16,992
Contradicts the findings of the American Trucking Association.This??
Actually, there IS a good reason to buy bias trailer tires over radials aside from cost, especially with 2 or more axles. We've all turned our trailers in a tight radius- ever watch the inside-radius tires when doing so? The sidewalls squish and twist substantially. With radial tires, over time, this causes the sidewall cords to fail. This is why you hear of so many trailer tire blowouts. Good bias trailer tire sidewalls barely squish or twist at all. In a hard turn the tires just slide. The sidewalls never get hurt, so blowouts with bias tires are extremely rare
http://www.goodyeartrucktires.com/pdf/resources/service-manual/Retread_S7_V.pdfThe issue of irregular tire wear has always been a concern even in the days when most trucks ran bias ply tires. With today’s longer wearing radial tires, irregular wear has surfaced as the primary concern of most truck maintenance managers. In fact, it is the ability of today’s advanced radial tires to deliver long original tread life which requires even more attention to good maintenance practices and vehicle alignment. Radial tires have a different footprint shape than bias tires. These results in less scrubbing and longer tread life. However, this same attribute of the radial design can also result in the tire exhibiting more irregular wear when vehicle and tire maintenance are below par. These wear patterns are not as evident in bias ply tires. Since the tread wears away usually much faster on bias tires, unusual wear patterns are literally scrubbed off as they develop.
Personal experience....three tandem axle trailers, 20+ years,150K+ miles later, no problems running radial tires on tandem axle trailers.
