JesterGrin_1
Thread starter- Joined
- Jul 10, 2014
- 47
The Cowling says Johnson Tracker. So are these real Johnson motors or are there a difference between a motor marked only Johnson and made by Johnson or a Johnson made for Tracker?
Another question the person says it will not shift into reverse but Forward and Neutral work fine? Any thoughts on this?
And the compression for both cylinders is 140 which sounds good.
With the above information what would a motor in this condition be worth or even worth messing with? Thank You.
