Mercruiser sterndrive shaft
Bt Doctur
whats that object still on the shaft? that needs to come off. #`s 84,85,86,87,88
Is there a chance that it is an oil seal? If it is how difficult is it to repair? Just slide it on or something more invasive? According to the schematic there is an inner and an outer seal.
Ayuh,.... Yer picture is Gone, I can't see it, even after clickin' it up,....
Bt Doctur
The shaft seems solid. I haven't checked the oil. I will let you know. If it was the seal, there wouldn't be any oil at all int he lower unit right?
Watermann
Is the object hollow like a seal or solid like a washer? You can see the prop shaft seal is still in place and no oil is dripping out.
