ns8b 3B2-1- serial number 66172 - change carb to 9.9 ?
Lund_bC
wondering if i can change the carb in this motor and it turn into a 9.9.. if so where can a buy a carb ? thanks
Lund_bC
also i am not 100% sure what year i have if it matters
Sea Rider
You could turn that 8 into a 9.8 if that's possible. At least on newer engines it's a carb swap . You can't turn a 8 into a 9.9, different HP powerheads.
Happy Boating
pvanv
No. The 9.8 carb will only work for SN 77531 and above.
Lund_bC
hi, getting back to this quesition, i have a car mechanic here that says i could change the carb on this to a 9.8 but maybe as he isn't a outboard mechinic i shouldn
t waste my money.
What is the difference between these serial numbers and why wouldn't the new carb fit? is there anything that can changed to make it fit ?
Lund_bC
WHY, Find another project, or buy a bigger motor
because if i can change the carb i get a bitter motor, not easy to find a decent outboard around here, especially not a light two stroke motor. Alos i am not rich i am a DIY kind of guy and work with what i have, changing that about myself would include a complete lifestyle change and one i wouldn't enjoy.
flyingscott
Keep the motor you have the 1.8 hp you will gain will not make a huge difference in the power if any. Find a tiny tach and and get your motor propped right to run at the top of it's RPM range with a light load.
