sevanseriesta
Thread starter- Joined
- Jul 12, 2012
- 303
Ok, so here is the deal. I am pretty good with engines, but this one has given me the same problem that I can not fix. This is a 2007 mariner 9.9 4 stroke. It will run while the choke is on, and the rpms are up. If you take the choke off then it dies right away. If the engine is cold, 8 hours or more, it will start up with no choke but will die after 3 or 4 mins. I can not start it at all when its warm with out the choke.
I have done a compression test, 138, and 136. I have taken apart the carb and completely cleaned it. When I clean it it starts right away, runs for a little bit, then dies. I have checked every fuel line, no leaks, no breaks, motor is super clean. Any ideas. I have seen and read hundreds of posts just like mine but no one has the fix in there thread.
This is not my motor so I do not have a manual for it. If anyone can help me, I will be greatly in your debt.
