This Ship of Fools
- Jul 8, 2010
- 21
I have an 1989 Maxum 19 ft with 3.0 and Alpha one gen 1 out drive Replaced water pump in lower unit and also replaced the gimbal bearing and u-jpints. Started boat up everything is fine no more bearing noise and engine runs cool. The problem I'm having is the the prop is engaged and spinning when the engine is started in neutral Did not try to shift into forward or reverse while it was running ( didn't want to break anything
Should I drop the lower unit again and try to reinstall or is there an adjustment I can do? If I put the remote into forward gear while the engine is off I can move the shift shaft on the inner access under the unit a little and the prop will spin freely in both directions
