udoittwo
Thread starter- Joined
- Jan 23, 2014
- 73
Hello again,
Apparently the marker I used to lable my connecting rods didn't hold up too well. I have 2 rods that most of the marker came off. I believe they are in the correct order and I can make out most of the mark. I am 99% sure they are in the correct order but I was wondering, what is the importance of the correct order? The cyls have been bored, the crank polished, new pistons & rings, needle bearings, ect. On auto motors I've built, I have had to replace a rod for one reason or another and often just grabbed a used one and went over it and never was concerned or had a bad outcome.
There is no markings on the rods to differentiate. Just wondering?
Oh, I did make a painfull mistake that I only made once. I've only build motors using bushings. On those motors, when I would assemble the rod to the piston, I would put the retaining clip in one side to use as a stop for the wristpin. So, I did that. I used the peice of the wristpin to hold the needle bearings in place[worked great] then, as soon at I went to put the rod inside the piston I realized what I did. Because I don't have spare clips, I had to assemble it that way. Instead of 5 minutes, I spent an hour and a half trying to get it together. Finally, I took it all outside where I had excellent lighting and put it together on the first try. The other 4 went together in a few minutes each.
Hopefully, you can answer my ? on the rods. Although there is only a slight chance that 2 are switched, it bothers me.
Thtnka again,
Karl.
Thtnka again,
Karl.
