3 blade or 4??
ron548
I have the option to go 4 blade on my 1975 15hp johnson it flies wot on my 14' john current prop is a 3 blade, will ther be any advantages with a 4 blade?
Thanks Ron
Sea Rider
Welcome to Iboats,
If you don't provide max achieved wot numbers with you alone, lightly loaded bosat on flat calm no wind waters anf GPS speed it's a wild guess...Must install a induction tach. What are you trying to accomplish ?
Happy Boaring
Sea Rider
Welcome to Iboats,
If you don't provide max achieved wot numbers with you alone, lightly loaded boat on flat calm no wind waters and GPS speed expect a wild guess...Must install a induction tach. What are you trying to accomplish ?
Happy Boaring
ron548
I'm happy with the 3 blade performance, but if the 4 blade will give'r more go I'd go with the 4. the boat usually 1 person with fishing equip& deepcycle
MikDee
Banned
It won't give you more speed, but a better hole shot, and quicker response to the throttle.
jestor68
A 4 blade won't give her more "go"; if by that you mean more speed. It might accelerate a little faster to plane, but run a little slower at top speed due to increased blade area causing more drag at high speed.
Unless you're needing better "grip" at the expense of top speed, I'd stay with a 3 blade.
Sea Rider
Anyway, which size boat, which HP engine, which max stated HP engine are we talking about ?
Usually standard factory delivered props on portable motorrs up to 50 HP engines placed on light boats gives good or near max wot rpm factory stated for that engine. Will need your wot numbers to check if inside min-max safe wot parameters, then can go from there selecting a pitch that's best for your current boat/engine appications.
Happy Boating
