firing problem on a 2.5 omc
stonepony86
not get fire to the ignition coil does it get its fire from the alternator or the hot side of the ignition
Ayuh,..... From the Points,....
Ignition power to the (+) side of the coil, the (-) side of the coil to the points,....
stonepony86
ok thanks im not getting any fire out the coil i put a new coil on and nothing i hooked it up just like they had it on the + side i got to wires a purple and a yellow with red stripe the purple wire run down into a plug that comes out and hooks to the starter and the yellow one goes from coil to alternator and on the - side i got a purple wire which i havent really traced yet and a black wire that goes to the distribitor
Ayuh,... To the Points, 'n yer Problem,....
stonepony86
i can take main spark plug wire off and hold it while turning it over and nothing doesnt bit me at all also when i bought the boat the ignition was working now its not could the ignition be bad
Ayuh,.... The POINTS,....
