bengaltiger14
Thread starter- Joined
- May 14, 2012
- 48
2005, Sea Ray, Mercruiser 5.0L MPI
So my wife decided to crank the boat up while beach on sand for over 20 minutes, thus shredding the impeller. I did not realize it until we took off and the gauges were reading only 1.4 or so psi at 35 mph. It did overheat at idle but there was enough water pressure to cool the engine off at higher RPMs. So, I disassembled to water pump to find the impeller shredded with only 1 vane intact. I found 2 other vanes within the water pump housing but did not find the remainder. I checked the hoses and thermostat housing. I reassembled the water pump and the pressure appears to be ok. Should I be concerned???
