Putzaroni1
Thread starter- Joined
- Oct 20, 2012
- 108
I pulled the leg off of this motor because it was not pumping any water through the telltale. I attached a hose with an adaptor to the copper water feed pipe coming out of the top of the motor and water came out of the telltale good. I did the impeller and replaced some of the O-rings so it would seal up and when I started it, no water from the telltale. I remember someone saying that possibly the copper tube didn't go into the rubber seal it plugs back into properly.
Is there a way to test the lower unit when I have it off ? I'm going to have to pull it off anyhow to track down where the blockage is.
Any suggestions or tricks ?
