Texas Redfish
Thread starter- Joined
- Feb 2, 2014
- 8
1) Tilt/trim is stuck. When I push the up or down button, the only thing that happens is the relays click. I replaced the relays - no result. No fluid leaks, etc. Before the tilt/trim stopped working completely, it worked intermittently for a short while.
2) Same outing - motor started running rough, and won't idle properly. I installed fresh plugs, and noticed the top right cylinder as viewed from the rear had burned the plug black. :faint2:
I recently replaced the powerpak and had the carbs rebuilt.
Any help would be greatly appreciated !
