1993 Johnson 115 hp Broken VRO pump!!!!
Status
Not open for further replies.
Army3
Hello,
I need a little help with my VRO pump. A couple months ago my buddy and I rebuilt cylinder #1 on my 93 115 hp Johnson
In the process of disassembly I broke off one of the ports on the VRO pump, after several attempts to repair ( with no avail)
I am wondering if there is an alternative to buying a new $400 pump. I have read where some people have had luck with a 3 port fuel pump but I don't know if that application would work on my engine. Any help would be greatly appreciated. Thanks
Daviet
Re: 1993 Johnson 115 hp Broken VRO pump!!!!
Welcome to the forum.
You should be able to convert your engine to a regular non vro pump. If you run a search you should find a lot of information on it. You will have to mix your fuel manually to a 50:1 ratio.
Army3
I have done some research and I've seen two different types of pumps, one has only two ports which mounts somewhere on the engine, the second one has three ports and I believe it is run off of the "compression line" (sorry I don't know the proper term) has anyone used one of these?
Daviet
A vro pump uses a pulse line to make the pump work. You need a 3 port pump, like the one below, and are going to have to make a mounting bracket to mount it to the engine somewhere. You will have to rerun fuel lines to make everything fit. Make sure and purge all of the straight fuel out of the system and use the primer bulb to fill the the system with premix fuel before you start the engine.
:: iShopMarine.com ::
Army3
Thanks a lot for the information. I will being searching for a pump now and hopefully finish my year and a half project. Will update on progress. Thanks again.
kenmyfam
Good Luck with it.
Status
