Adam Leyva
Thread starter- Joined
- Aug 28, 2013
- 4
My dad and i are going to try to restore his old Mckee Craft. I will try to get some pictures up tomorrow, its too dark now.
I would first like to know, since i cant find anything about it anywhere (in detail). How were these boats made? I think he said it was early 70's. Definitely 70's though.
I know they were pretty much a BW copy, but im curious to know what exactly is inside the hull. Is it just foam? Are there stringers? If so, were they coated in glass? Is there any wood? If so, was it coated in glass? Can it rot easily? The transom is still pretty strong, but im curious how that was made, too.
I also have some questions on gel coating. How exactly do you do that? I have a rough idea of what it is (being that i surf, i have done some fiberglass work and do know a bit about that). But is it kind of like painting with poly/epoxy resin? Whats the best way to go around that?
Finally (for now), theres some damage, dont really know how to explain (gotta get those pictures) but since you all have been around boats a while, they are from hitting waves out at sea going fast. They are located at the bow and about six inches forward from the transom on both sides. Im assuming, since theres foam inside, the foam has been cracked. The outside is strong and only needs minor work.
Sorry for the overload, all and any help is very appreciated!
Thank You, Adam
P.S. I WILL get some pics up soon!
Thank You, Adam
