OMC,460 ford
expedition175
I want to know some simple thing i do for give to my 460 ford a few horse power. Thank you for your counsel.
WillyBWright
Re: OMC,460 ford
Bigger CFM marine carburetor, or thru-hull exhaust if you don't already have it. Those are the most economical ways to boost it.
DHPMARINE
Re: OMC,460 ford
You could also run solo_Other people n the boat makes drag in th water. :)
rodbolt
Re: OMC,460 ford
you could tell us a bit about your rig as well? the fastest way to increase HPO is to change the valve cover decal :) <br /> good luck and keep posting
Don S
Re: OMC,460 ford
Old 2004 thread
HT32BSX115
Re: OMC,460 ford
I always get excited when I see an OMC 460 thread!!
Too bad you can't make the date/time block flash in red or something when it's 6mo or a year old so it's more noticeable.
It's easy to miss the date!
Re: OMC,460 ford
Ayuh,....
That wouldn't be necessary if the Newbies would just Read the archives,....
Instead of responding to 4 year old threads......
rodbolt
Re: OMC,460 ford
easiest way to change the horse power output is to simply change the decal :)
cant belive I have been posting this long, man I need a wife or a life. sumpthin
D
DJ
Guest
Re: OMC,460 ford
Seriously, the easiest way to get a 460 to perform better is to make it breathe better.
The heads on 460's (pre-1993) were somewhat restrictive. A lot could be done with the intake and exhaust systems to help but opening up the heads wakes them up.
That's what Ford did post 1993 with the PI (performance improved) series of engines. Along with the heads (PI) there was some cam tweaking.
Don S
Re: OMC,460 ford
Oh yea, forgot about that one.
Guess I picked a bad day to quit drinking
Oh, BTW, its still a
2004 thread
baconbiscut
Re: OMC,460 ford
When we repowered our boat with a 383 MPI I kept the mercruiser 260 flame arrestor cover and I put it on the new engine. I still haven't seen any decrease in HP! It looks kind of funny everytime I open the engine hatch and It says Mercruiser 260 Alpha One, Power stering, Thunderbolt Ignition. When in fact I have a Bravo One, 325 HP, And Fuel injection.
mcleaves
Re: OMC,460 ford
But 2004 was a good year! I sold my Bayliner with an AQ 125 in that year.. Ahhhhh.. Good times... No more stress. ;)
M
HT32BSX115
Re: OMC,460 ford
I donno...I still like my way....pull the thing out and sell it to someone to put in a pickup!
