1970 70HP chrysler
Status
Not open for further replies.
robm30
i have a 1970 7o Hp outboard that won't turn over when spark plugs are in. when i took out it turned over no problem can anybody give me any ideas what would cause this
gg18189
Re: 1970 70HP chrysler
weak battery, weak starter, check both and try again:wave:
jerryjerry05
Like GG suggests,check the battery.Clean the starter. Check the connections, grounds too.
Then do a compression test. Low comp can cause hard starting.
59erdiner
ImWondering if anyone knows if a 1973 707HF LOWER UNIT Will fit on my 1969 7071 motor Thanks in advance for any answer
Joe
Fun Times
Joe
Hi Joe, welcome to iboats The hosts of iboats would prefer that you start a topic of you're own vs tagging onto someone else's especially topics that are older than 90 days like in here. Please see the "Help Tip" at the top of the forum page for more detailed information about forum hijacking.
Also, I went ahead and took the liberty of starting a new topic of your own titled 70 HP Chrysler lower unit swap question please. Thank you and good luck, iboats moderation team.:)
Status
