louisvillefisherman
Thread starter- Joined
- Oct 13, 2012
- 29
I am attempting to set the throttle sync on my Johnson 9.9 as a step in diagnosing a larger issued I am currently having.
From what I have read, there is a hash mark on the top of the cam (found it) and it is supposed to line up with the roller when the pivoting action of the roller being pushed by the cam results in the butterfly just beginning to open.
My problem is that the hash mark is too far past the roller, maybe a 1/4 inch or so. I would have to turn the throttle way to much in the "power down" direction to be able to get that to line up and I cant because I am already at the lowest idle position on the grip.
I know there is an allen screw on the open end of the cam that essentially makes the cam "fatter" thus effecting when the cam hits the roller, but it does not seem to effect the location of that hash mark.
To visualize , if I were looking into the throat of the carb, the hash mark would be too far to the right of the roller. I would have to turn the throttle backwards (decelerate) quite a ways to get it to the center of the roller, but of course I can not because I am at the bottom end of the throttle twist range already.
What kind of problems would a poorly aligned throttle roller / hash mark create?
And what should I be looking at in order to get that line to come closer to the roller?
