OMC 5.7L loss of power
Status
Not open for further replies.
liquidasset
I recently purchased a 1987 Four Winns liberator with an OMC 5.7L. Ive had the boat in the water twice now and cant get it to go over 2800RPMs. When I push the throttle farther it starts bogging down. So far Ive checked the timing advance and secondary butterflies. You also have to really baby the throttle to get the boat to accelerate. If you give it gas quickly it will bog down. It only does this under a load too. In nuetral she'll rev up to 4400RPM easily. Im going to rebuild the carb this weekend. Ive seen a lot of posts with this motor and problem but havent seen anyone fix it yet. Help please.....
Roger030
Re: OMC 5.7L loss of power
Im having the same problem at 2800 RPM, Ive tried rebuilding the Quadro Junk but no help. Im running a 24 pitch prop and Im going to try a smaller one to see if I can raise my RPM to get more flow through the motor and open the 4BBL the rest of the way up. Ill post my findings. Im also running the exhaust through the lower unit and Im wondering if its confining it too much. It is a 350 with a electric shift 65 OMC lower unit.
liquidasset
I bet that your exhaust isnt the problem. Ive got thru-hull exhaust and Im experiencing the same exact thing. Ive seen post after post on this problem. Does anyone ever get their boat running right after experiencing this? If they do, they need to post what they did to fix it.
rodb267
i have a freind with 5.7 omc similar complaint, engine runs fine no load, ran compression test all cylinder 165 psi to 180 psi, had replaced plugs, wires, cap,rotor, even carb.,checked fuel pressure all fuel lines chaek valves hoses
etc, even went as far to check cam timing all ok no slack in timing chain, pulled valve covers to inspect valve train movement all seam fine, i was hoping to find a worn camshaft, when using vacume guage engine has strong
steady vacume round 18 inches at idle, under load 2800 rpm vacume drops to
about 12 to 14 but engine/boat wont get out of its own way. even tried going from a 17 pitch to 15 pitch no change, next i am going to remove exhaust manifold and inspect flappr valves to make sure they are not stuck causing excessive backpressure but i would thing vacume guage would go into a positive reading if this was the issue. this engine runs like it doesnt have any compression as if rings were shot but no blow by, no oil consumption, i havent done a cylinder leak down test yet but i am sure this is going to be my next test, i dont know what to tell you folks but i am diligent and will let you know what comes up when i continue to diagnose when the ice has cleared this season, anybody who has any suggestion please i an open to all input, this seems like a common problem with this engine, please note this engine also had an breakerless ignition installed , it almost feels like my boat when i have all of my fat buddies sitting in the back and have to move them up front to get my boat up on plane, but i already had 2 of my large buddies ride in front of this boat and still no good , anxiously waiting for any input, thank you rodb267.
Don S
Welcome to iboats rodb267.
Best to start a new thread with your queston not tack on to an old 5-6 year old post just because it's a similar problem.
After a reply or 2, no one will see your post.
Status
