Cutoff Switch/no spark Problem 33 HP Johnson
sapper29
1966 33 HP Johnson: I have no spark in the bottom cylinder and have traced it to the cutoff switch. If I remove and tape off the black lead coming from under the flywheel to the centre post of the switch I get a strong spark, I start the motor and it runs great - but of course it won't shut down using the key switch. I have checked for cracked wiring under the flywheel and tried a cutoff switch from another motor - no luck. Could this be a vacuum not wiring problem? can I ground the lead elsewhere so that the key switch works? Can I bypass this switch completely and maybe install a cutoff toggle near the key? I am really stumped.
Joe Reeves
Re: Cutoff Switch/no spark Problem 33 HP Johnson
The wire that leads from under the flywheel connects to another wire at the center point of that cutoff switch. That other wire leads either to a push buttom stop switch or a ignition switch. I stropngly suspect that this second wire is either shorted out somewhere or is connected to a grounding component..... trace it out.
lindy46
Cut-off switch has a vacuum line connected to the engine. Under high vacuum (runaway) the switch engages, and grounds out the cylinder. If the switch is broken, and always engaged, that cylinder will not fire. You can check the switch with an ohmmeter to the side post and center post. You should normally have no continuity. Suck on the vacuum hose and you should have continuity. Of course, you can bypass the switch by connecting the wire from under the flywheel directly to the wire going to the ignition switch, but I wouldn't recommend that, as the motor can't be killed during a runaway.
sapper29
Thanks a million for this. Sometimes I stare at a problem too long and don't see the obvious. I had grounded the radio to an M terminal in the starter switch. Redid the switch today and took a common ground from the battery to the front of the boat for the accessories.
Just fired her up and sparks all around.;)
Joe Reeves
DO NOT ever ground anything to the "M" terminals...... Why? Well. I'm glad you asked........
Any component or accessory that has voltage (normally 12 volts) applied to it has that voltage running thru the component/accessory and finally out of that component/accessory thru (usually) a black wire to the negative side of the battery either directly or indirectly. This means that the ground wire of that component/accessory contains voltage. The result is (if connected to either "M" terminal) that voltage is now being applied to the points, condenser, and the coil..... really not a good idea!
carpking
I am having a similar issue on a 72 Evinrude 40hp. I did the above test with my meter and I DO have continuity from side to center posts on cutout switch. I have no broken wires that are grounding out. So, can I conclude that my cutout switch is defective and needs replaced? The motor has new points, condensors, coils, etc but no spark on bottom cylinder. Thanks.
boobie
This post is over 3 yrs old. Read the rules at the top of the forum and please start a new one.
