1976 evinrude 115 no spark
Status
Not open for further replies.
baxter8181
i have a 76 evinrude 115 that has no spark on any cylinder. tried with the kill wire off, still no spark. has brand new power pack. magneto ohms good. timing base has 8 ohms but only .03 volts while cranking. im pretty sure the cranking rpm is fast enough. any ideas?
baxter8181
Re: 1976 evinrude 115 no spark
power pack is brand new but i guess it wont hurt to check again
ezeke
Read through the troubleshooting steps, there are other possibilities.
If you are not checking for spark with all of the plugs removed, you are not doing it correctly.
The timer base is adjustable, don't replace it without checking it first.
If the rectifier is bad and allowing voltage to reach your stator, the stator may be damaged.
baxter8181
more info. boat ran perfect then all of a sudden it acted like it was running out of fuel. i make it back to the dock and took it home. a couple months later i got around to seeing what happend to it and it only had spark on one cylinder. replaced the power pack and now it has no spark on any cylinder. magneto tests good. new power pack tests good. is it normal for both sensors in the timing unit to go bad at once?
baxter8181
the rectifier tests good. tried adjusting the timing sensors, no change
Daviet
Do you have an OEM manual, you could use the troubleshooting section to find your problem. Sometimes if you replace a component without checking out the system you can blow a new componet and end up chasing your tail.
ezeke
How did the stator look?
Have you disconnected the wires (especially the ground wires) and cleaned the connections?
When you disconnected the black and yellow kill wire, did you do that at the powerpack?
baxter8181
i dont have a manual. got one ordered. i unhooked the black an yellow wire at power pack. i have taken everything apart and cleaned. everything ohms good.
Status
