plug wires
scoflaw
Ensign
Are merc wires worth the 100 bucks? Or should I head to auto Zone. Noticed I've got a firestorm accross the top of my cap.
erikgreen
Re: plug wires
You won't notice a difference except in looks between Merc and a similar quality set of wires for a car.
Of course, then your boat won't be "all Mercruiser", so if that bothers you...
Erik
TyeeMan
Master Chief Petty Officer
Re: plug wires
A couple years ago I picked up a set from West Marine, they seemed like a quality product, I think they were only $20.00 for a 4 cyl. Not sure if there is a difference between marine and automotive wires. If you haven't replaced your cap and rotor lately I would replace them to right away, , the cap and rotor I would highly recomend using OEM stuff. I know from experience that there is a difference in quality.
JustJason
Re: plug wires
lug wires are plug wires. The problem with getting non-marine application ones at an auto parts store is 2 fold
1. They aren't long enough to clear the exhaust manifolds. So a set for any old chevy V8 usually does not fit a Mercruiser V8. 6 out of 8 may fit, but the last 2, (the 2 longest ones) are to short.
2. The cap to coil connection wire is usally different because Marine distro's and coils are different than their automotive counterparts.
sethjon
Re: plug wires
Car wires will work fine but make sure the lengths are enough.
bigdan1
Re: plug wires
merc plug wires at $100.00 they surely buy them from a wholesaler ....
buy car plug wires , they will be up to par !
erikgreen
Re: plug wires
The only problem I had with the last set of wires I bought (for $25) for my Mercruiser V8 was that they were too long and didn't look neat...
wire2
Re: plug wires
The simple way to ensure you get the correct length is measure the existing ones, take the numbers to the store and measure new ones. It's a crap shoot to get them the fit perfectly.
It's a good idea to put a film of dielectric or synthetic grease inside all the boots. It keeps them waterproof longer, and makes pulling them off the plugs much easier in 2 year's time. (1 hand, instead of 2)
Todd157k
Re: plug wires
I think the Accel wires come extra long and you install the ends.
