doryfishin
Thread starter- Joined
- May 27, 2010
- 19
hi , i have good spark on both cylinders , good compression i have cleaned carb out , replaced hi and low speed coils yet still i only get half throttle . i pulled ht leads only to find no1 cylinder not firing yet spark is good when plug is out . it will start on no2 cylinder without no1 cylinder plug in i dont know what else to try i dont have any way of checking timing as it needs to be checked at wot and i run the risk of blowing it up in my test tank as all the water flies out the tank . any other ideas on thi will be much appreciated thanks in advance .
