farmboy4life
Thread starter- Joined
- Aug 15, 2010
- 4
hi i have a 1980 bayliner bow rider with a aq120b volvo motor with a closed cooling system and a 270 drive now my problem is it will overheat at 1/2 to full throttle i have checked all the water lines and sea water pump has been replaced , the heat exchanger is clean the thermastat is working i tested it and the timing is on just checked it i am lost can it be the coolant pump or the pick up lines sucking air please help
