frogstomper1
Thread starter- Joined
- Aug 6, 2010
- 5
I've got a 94 200 2.5 Mercury. Always ran great for me no issues. A few weeks ago I noticed it to be a little sluggish while getting on plane, and would smooth right out once I was on top. It almost sounded like it dropped a cylinder or two while trying to get out of the hole. After getting back that night, I dug in... Plugs 2 and 4 very wet and black, all others ok. Compression is at 125 all around. Spark on every cylinder, got 198 volts with my DVA on all cylinders. Opened carbs up looking for some debris---nothing. Rebuilt fuel pump as diaphragms were original. All filters replaced after carb job. Visual inspection of reeds for damage or one hanging open---nothing. Statically checked base timing and W.O.T. timing---both right on the mark. Checked all recirculation lines---no kinks or breaks found. Thermal valve is operating correctly, as is enrichner valve. Took it out the next day, still a bit puzzled, same thing. Almost like it's loading up #2 and #4 at lower speeds, and then smoothes out once at high RPM. Am I missing something? What else can I be looking for? Thanks in advance.
