chrislovessadie
- Aug 5, 2010
- 10
I have a Mercury 1986 or 87? 150 XR2 Black Max, Bought this boat in Nashville, Tn. last year, boat ran awesome and fast, you just had to push the throttle in slow until it warmed up. Got married and moved out to south west CO, and took boat out. Will start right off the bat, but as you engage the throttle it wants to bog down, I can only get it to go about 5 mph or it will stall out. Had high altitude jets installed, carb's rebuilt and cleaned, gas tank flushed, went from a 3 blade, 23 degree down to a four blade, 16 degree prop. still will not get up and go. just pulled main jets with motor running and had gas coming out. So I then pulled spark plug wires off one at a time starting with the upper left one(#2) and working my way down. #2 did not have spark and #3(right side, second from top) and did not change idle at all, the rest of them made it idle rough. I then took the coil pack from #2 and changed it with #4, (and 4 on 2) still no spark, Saw a online forum that said two wires don't fire until rpm's are up any one know if that's true? Also yesterday, on lake when trying new prop, it will die and sometimes I will have to use the fuel primer bulb to get it to start up again. But run the motor with muffs and it seemed to rev up nice, starts first time. Just cant take a load when engaged , Wondering if anyone on here had any ideas of what it might be? Thanks!
